iCarsoft MB V2 or get a star done by an indie
Botus
S500/2010/500
on a lot of the ebay ads (particularly for beru on BMWs) they all sell the controller and the set of glow plugs as a kit
NBurns
Sunny Hampshire by the sea
www.facebook.com
A180 CDI AVANTGARDE SE CVT,169.007, 2009
NBurns
www.facebook.com
Mine is currently on version 19.07 according to this screenshot:-
W245207
W245 B180 CDi 2005
It doesn't, you have to periodically run the update tool which itself gets updated (3.13) from time.
W245207
W245 B180 CDi 2005
Copy the "deviceinfo" file from the memory card and keep it safe on your pc. If for whatever reason you need to format the card and you can't run the update despite manually entering the serial number and uid. You can copy the file over to the blank memory card and it will start the update and download the files from iCarsoft server. This will restore your MBv2.0 device.
D
dav1971
East Yorkshire
CLK 2000 2.3K Gone, CLK 2002 320 Gone, Now ML 320 Sport 2005
  • #67
on the glow plug control box (aka relay) they get superseded, get old stock and it'll come out lower than one they just made.
bearing in mind the 12 year old one had HW and SW version from 2004, a 2010 or 2014 version is unlikely to do much other than be better than the worn out original
when I put one in my father's v6 tractor there seemed to be at least 5 versions between the one I fitted and the one it had, seems to drive just the same before and after, it probably just gets a more accurate die age built in
these where the bits I noticed when sourcing one on his e280 cdi v6 the 900 looks different to the 153 ones but all plugs in and works the same, but do need to reroute a cable so it fits a bit better
A642 153 0379 SW10/04 HW01/04
A642 153 2079 SW40/05 HW01/04
A642 900 5801 SW22/12 HW17/10
A642 900 7801 SW26/14 HW20/14
Thanks for the info.
I have ordered a timer relay and should be with me tomorrow.
I am pretty sure it is the relay now, when I was starting before I would just jump in the car put my foot on the brake and hit the start button. For the past nearly week I have been getting in, hit the start button to bring on the ignition but not fire, wait for the glow plug light to go out and then wait a few seconds more and then hit start with foot on the brake and it fires up straight away with no smoke.
When starting with foot on the brake the car would delay until the glow plug light went out and then try to start straight away, doing it manually and leaving a few extra seconds seems to be the best way so am thinking the relay is worn out and not delaying long enough for the plugs.
I'll update when I get it fitted.
Terrykal
Hertfordshire
C219 cls55 amg
That a good question. I had the same question today to be honest. I had a quick look online and didn't find an answer.
W245207
W245 B180 CDi 2005
Memory card is playing up
Re-installed via update.
philreed52
270clk
Also while I was at the indie last Thursday I waited for the Star Diagnostic to be done as I didn't want to pay for a taxi home only for them to call me with a price to fix that I couldn't afford, I live in a rural area so getting a taxi is expensive and hard to get.
I was listening to conversations going on and it seemed there was a new girl and she was talking to the service manager about doing an invoice, overheard him say yes it is 4 x injectors.
When he told me that there was no codes from the Star and that I need to bring it back for a cold start test I reminded him that I told him this was what was happening and that my local garage had done tests and found 2 injectors faulty which I had him fit and no codes showing.
He then said, talking about the invoice I overheard about the 4 injectors for another customer, we would replace all as the others could fail in a week :eek:, mine is a V6 so if I had taken initially to them they would have quoted to replace 6 injectors which I said to him and he agreed:eek:.
Is it me or is that like having a tyre blow out and replace all 4 just in case the other 3 might do the same in a week? Local garage said that yes other injectors can go faulty a week later but they can also go on for years. Even to have the option would be nice but indie said that it is their policy to replace all.
On the Indies literature they boast that they are the largest independent in the UK for car and commercial, while sat there I did feel like a bit of a small fry while wagons where coming in out and got the impression that they couldn't be bothered with something as trivial as my car unless I was going to hand over wads of cash.
Also forgot to mention on the parking sensors that they found that the outer 2 rear parking sensors are at fault, my local garage had said this to me but he said he wasn't 100% sure. Local garage said to buy a couple from Ebay which are under £10 each, said he would need to drop the bumper and said he would do it for £80, also said he had a spray touch up so I wouldn't need that.
Indie quoted me £341 to do.
Wish I had bought the iCarsoft now as the money spent on the Star and taxi's would have nearly paid for it, £72 for the Star and £42 in taxi's to be told what my local garage had told me :(.
Sorry on late quote having a had recently similar thing with indy specialist .took my lovely 2005 270clk to him with a problem and without leaving office told me to run it till it stops throw it away and save my money for something newer.I left at that point . It is old but I like it and will get it sorted ,getting some help from forum on another thread. Clearly doesn't need the work !
Sent from my SM-G950F using Tapatalk
Terrykal
Hertfordshire
C219 cls55 amg
I am a little puzzled and would appreciate your assistance.
Based in your experience, does icarsoft reads correctly the door modules or mistakenly names them based on left hand drive vehicles?
I am asking this because it seems that, according to icarsoft, my left front door module has the boards and functions for i.e. the trunk lid but it's not since my car is a UK rhd and the boot's button is on the right front door (UK driver's door).
Any thoughts?
I am asking this because there is a current code for the right front door (according to icarsoft the passenger's since this module doesnt have the trunk button etc) that says there is a short circuit in my heated mirror system.
Thanks in advance.
In my experience if you correctly answer the Left hand/Right hand steering question it gets it right, but that's not to say that your specific variant is correct.
Terrykal
Hertfordshire
C219 cls55 amg
Lostkiwi thank you for your reply. To be honest i have used it about 5 times till now and none of these times I saw an option to choose for Rhd or Lhd. Maybe I am going blind or something. From what I can recall now, when it comes to model, I can only choose year period and then exact model i.e. 219.375
From memory it's the next screen after selecting model. You may need to update to the latest software.
Terrykal
Hertfordshire
C219 cls55 amg
Thank you once again for your prompt reply.
I bought it only a couple of months ago and it was advertising that is up to date and this is why I didn’t bother to update it myself.
I will try to update it today and have another go. I will let you know. Many thanks.
Oldspanners
Normandy
C CLASS 2004 C180
I bought one from UK Parts Direct a few weeks ago and it needed updating out of the box but easy to do, log on to the site, find the update link, plug in the iCarsoft and in a few minutes it's downloaded.
Have fun, I did.
Terrykal
Hertfordshire
C219 cls55 amg
I just updated my icarsoft mbv2.0, all went good but still seems that it is missing the rhd LHD option.
According to few videos from YouTube I saw that the option is just after the diesel/gasoline menu and before the exact engine variant.
I will contact icarsoft team because it is very very strange.
PS: till now only issue is that it thinks the left front door module is the main one with the trunk button etc. But when going to view measured data it correctly reads the data from each door (meaning the Amps or window position height or mirror adjustment). So at least I know that my error fault has to do with my driver's rearview mirror glass.
