Ice Tanks For high Power AMGs
Acid@MSL
WEST MIDLANDS
C63 SUPERCHARGED
The use of this water tank upgrade will allow extended heat dissipation in all climates, and will also allow the user to apply ice to the intercooler system if needed to further chill the air charge temperature as it enters the intake path. The tank also contains a large capacity ball valve drain system, that will allow the user to quickly drain hot water from the system and add ice between runs.
Miffy
Bromley, London
CLK 320 CAB Elegance C208
Savman has this, or something similar. Boy did he get a lot of looks when he was queued up for a drag, and then seen pouring bags of ice into his boot :)
