Identification of the early Valeo Radiator?
MAB01UK
Apparently some early W203 C-class were fitted with a Behr radiator rather than the troublesome Valeo type. Has anyone got any information on how visually different the Behr is to the Valeo one when checked in situ?
Or is it possible to see the makers label on the underside without removing rad from the car?
I have a Jan 2001 C200K (RHD Dec 2000 German built saloon) 98K miles with original rad and from what I can see it looks like the rad is very similar to the Behr one shown in the US forum (picture below) ......ie. black ribbed plastic end tank with 2 small transmission pipe connections with wire clips.
On the Mercedes TSB pictures below (see figure 2 and 3) can anyone explain the visual difference between the "Old Crimping Method" (highlighted with 2 arrows) and the "New Crimping Method" (not arrowed) as the photos especially Fig.3 don,t seem to show very clearly what to look for?
I had a look under my bonnet with a small torch........the black plastic end tanks on my radiator appear to be crimped on to the rad with a continuous wavy silver metal strip all round the edges of the tanks. Each crimp is indented in a semi circular shape and is about 10mm wide with a small aperture in the base of each crimp where the metal has been formed. (Similar to the crimping on my old W202's radiator header tank).
The suspect crimping shown in the Mercedes TSB Fig.2 shows small metal square shaped crimp tabs about 5mm wide spaced around the edges (like the Behr rad photo) and bent over to crimp the tank in position.
Therefore does anyone know if wavy shaped crimping is ok and means you don't have an old Valeo rad.......also why does the USA Behr rad photo show the suspect square crimping if thats how the dealers identify potential Valeo problem cars? :confused:
If anyone has removed or is going to replace a Valeo radiator please post a few pictures of the old one before you throw it, to help us see how to easily identify the problem ones that should be replaced.
MAB01UK
  • #2
The quote below is from the US forum to go with the above Valeo radiator TSB and photos of the Behr radiator and helped me to identify what to look for on the car:-
"Also attached is a photo of the connections on the good radiator.
Note the 2 attachment points on the tank end shown.
That is where the tranny fluid connects.
This is the Behr radiator, which is GOOD!
You are looking at the passenger side in USA (ie right side if you were sitting in it)
the big hole is for the cooling system and will be at the bottom.
The pics in the tsb aren't very clear. What you are looking at is the view from underneath the car. As you can see from the pic of the rad., it's really about how the end tanks are attached as from the pic in the tsb, you can't see squat. If you have the type of radiator shown in this pic you are OK!"
__________________
MAB01UK
This link to a US forum thread has yielded some very useful information on this topic and cleared up some of the confusion, it is also a good DIY on radiator replacement:-
DIY Radiator Replacement
It looks like as suspected a Valeo radiator has straight toothed crimping of the rad end tanks while the Behr has a wavy strip of metal crimping around the end tanks (see photos below).
Therefore if you have one of the 2000-2003 cars affected this should be the easiest way to identify whether your car has a Valeo rad and if you should replace it before it fails..........
khairunnain
New Registration
c32 amg/2002/m112
Hi, sorry to resurrect this thread from 12 years ago.
Could someone lend me your eyes and check that my rad is a non-Valeo? The car is a 2002 C32 AMG so definitely one of the cars originally fitted with the problematic Valeo rads.
However when checking my radiator, the crimps on the endtank doesn't look like the straight toothed crimping of the Valeos. Im hoping a previous owner has changed it.
Really appreciate your help. IMG_20201007_213032.jpg IMG_20201007_213032.jpg IMG_20201007_212953.jpg
