hi georgerow yes the car has been serviced by local dealer, it all started after i replaced the head gasket and the wiring loom that sits on top of the engine, was told timing was out so had dealer reset it,changed air mass meter, changed v.o,p.relay, and still no good,
Hi again, When you put the new harness on did you maybe disturb/damage the various vacuum hoses. How about an air leak on the inlet manifold/throttle body?. Also as kth mentions the charcoal canister. Associated with this is a purge valve which if stuck open would allow fuel vapour through at idle, which it aint' ment to do, enriching the mixture upsetting the idle. Also...could be a faulty thermo valve which controls the purge valve!. Some more things for you to ponder!.
sorry georgerov for not getting back sooner, had a few problems at home,your last thread you mentioned the thermo valve, where is this on the e280, i`ve check the purge valve and it seems to be ok,
Welwyn Merx Limited is a family run business with genuine passion, dedication and 25 years of experience dealing with Mercedes-Benz and AMG passenger cars. Tel: 01707 395999www.welwynmerx.uk
