philip.ajsmith@btopenworl
- May 12, 2003
I have a high idle, the idle valve opens, (disconnect increases speed) but I suspect does not close (although the controller could be stuffed.
The valve is sucking somthing awful, if I disconnect the pipe from the valve to the cold injector there is a lot of sucking and the engine dies immediatly. Is this normal?
Also the bypass pipe is sealed at one end, can this be normal?
The engine will not start with the valve physically blocked so I do not suspect leaks elsewhere.
Anybody got any suggestions, I have ordered some s/hand spares but would like any opinions incase I fit them and nothing changes!!!!
