bazzman
- Oct 11, 2002
- Location
- East Riding of Yorkshire
- 2001 SLK 200 6-Speed
Hi All
My 1986 230TE has developed an irregular idle.
It's not very bad, just floats up and down by say 200rpm every 10 seconds or so.
In itself, it's not a real issue, but it's a dry Saturday morning, -makes a change - so I thought I'd check it out.
I've recently done plugs, airfilter, and the plug leads are 18months old, so I thought I'd check the OVP. Sure enough the connector pins were a bit corroded. I thought I would check inside, and it looked fine. Quite dry and seems free of broken solder joints.
BUT, I tried starting the car without the OVP and it starts and idles totally smoothly.
It would seem that somehow the OVP is faulty, but before I spend £50 on a new one, can anyone tell me why the car should run better without the OVP?
I thought the OVP was basically a fuse. Worked or it didn't.
Am I wrong?
Should I just leave the OVP out?
Cheers
Am I wrong?
Cheers
