Richard.Wilson
- Mar 20, 2003
I've just changed my trusty 230TE for a late '94 E320 Auto Estate, and coincidentally a friend has just bought a '93 E280 estate, both have the same problem....
There appears to be a glitch in the automatic idling. When driving at idle, as you do when reversing, no throttle, it surges up to 1000 rpm and back down, over and over. This makes it Kangaroo, worse than a learner in a Nova!!
Local dealer said most probably airflow sensor or the idle acctuator unit on the throttle body, but he cannot test these "old" models with his Mercedes diagnostic machine!! Swap the bits over with new until we find the culprit....£75 an hour ...I think not.
I'm going to a Bosch specialist, but wondered if this is a common problem?
Are there any other symptoms to look for. or tests I can carry out on the sensor or acctuator?
Richard
Richard
