ignition key won't turn
louisdeux
columbus
e320 1999
The ignition key won't turn in my 1999 E320.
The steering wheel turns freely.
I've replaced the batteries in the key, but it wouldn't turn before or after doing this.
don't know if the following is helpful. I replaced the engine battery a month ago and drove it since. Worked fine.
As you have a long plastic key that chances are the wire has broken on the transponder coil and an easy fix normally
brandwooddixon
Wolverhampton
S63 Coupe 2014
Do you have a second key to try with?
Incidentally you don't require batteries in the key for it to work in the ignition. It receives power through an internal the coil from the EIS.
