The other day I accidently shorted across 2 terminals in the engine bay by dropping some wire wool on them. I discovered that one of them is live even with the ignition off. The non-insulated terminals are connected to what appear to be 'Bosch' resistors or similar (located on passenger side of engine bay near diagnostic connector). At first the ignition light faintly glowed when turning ignition on, prior to starting, but is now permanently off whenever the ignition is switched on. Car starts and runs OK and all other dash instruments work fine. Have I trashed the alternator or some other component? If so what's the best way of checking? I'm not entirely sure that the 'shorting' is the cause as the car has been laid up over the winter and I'm not sure if all was well before.
