C200 goblin
Hey people, Im wondering if anyone knows anything about the ignition system on the C200. Its a S reg C200, with the thicker key unit with 3 buttons (I think DAS3)
The car has'nt been started in around 3 months since, late September 04. I went to use it last week and I cant get it started.
I have checked the fuses in the bonnet and nothing blown. The worst thing is that its hard to find any electric wiring diagrams. Even in the Haynes manual. I cleaned the red lense on the key unit and the ignition and no success.
The main problem is putting the key in the ignition. It just doesnt make that sucking tick noise, nor is it turning to any position. The steering wheel lock is on and cannot be released. I checked voltage to the electric steering lock unit, which has 11.5 volts to all wires except the brown earth (would bridging any of the blue wires to release this cause a problem). The battery in the boot is at 11.5 volts also.
This ignition lock thing is such a pain, I mean you should be able to at least have been able to release the steering wheel!
Is there any way possible to get this thing working, or is there a relay for it. It seems strange for it to play up like this after not using it for a few months.
Any kinda help would be appreciated. Thanks
