TVRTASMIN
I started to remove the key barrel for the ignition switch as per the instructions on the other MB website.
Plenty of jiggling as instructed but the switch would not come out.
Removed the two bits of 2mm wire and sprayed in plenty of WD40 but the key would not even turn after that.
Tried drilling but the bit snapped as the first part of the switch/lock is hardened.
I ground through part of this with an engraving tool but the two halves will not come out of the black switch/lock surround.
I will try cutting it into quadrants and take it from there.
Any advice gratefully received.:sad:
