Ignition Switch wiring diagram 1992 C230
pkeohane
Does anyone have a wiring diagram for the ignition switch on a 1992 Mercedes C230?
mattkh
England
A160 W168 1999 1.6
What is it you are trying to confirm from the diagram
With a little more info,maybe some help could be given
P
pkeohane
Ignition Switch Wiring MB230
The switch has been dismantled because of key problems. The connector came apart as the wiring harness was removed from the switch so the wires are scrambled. The wires colours are 2 reds, 1pink/red, 1 pink/green, 1pink/yellow, 1 green/white, a purple and a black together. The terminals on the switch have the following symbols: 50, 15R, P30, 15, 30, 15X, 30. Which colour wires hook up to which terminal? The vehicle body (Chassis) number is WDB1240232B784277. Would be grateful if you could help, Paul K
mattkh
England
A160 W168 1999 1.6
Terminal 50
The wire from here goes to the starter solenoid to energise it.
can you see the colour of the wire going to the starter solenoid. That should be the one.
