Immobiliser/Key problem
  • Thread starter Patricia Coghlan
  • Start date
Status
Not open for further replies.
P
Patricia Coghlan
:cry: I have a mercedes C180 1996 and for some reason my infa red remote key will not lock or unlock the car, or start. I know there is a method to get this back and running but what is it ? I have tried locking the passenger door, pointing it at receiver and putting the key to second position on the ignition but it still does not work. Any Ideas ! I am at my wits end.
teky
UK North East ish
not sure if this will work, put key in and turn to pos I and hold the lock button in till the doors lock or an audible sound is heard if nothing happens the put it to pos II and do the same, have you changed the remote batterys they might just be flat also clean the inside of the remote out including the button
cush
hamilton
HI IVE HAD SAME PROBLEM WITH MY C180 1996.CLEANED OUT REMOTE AND REPLACED BATTERIES.KEY WORKED INTERMITTANTLY AFTER THIS MB DEALER SAID KEY HAD BECOME DEFUNCT DUE TO AGE.REPLACED KEYFOB TODAY AND EVERYTHING SEEMS TO BE FINE PS FOB WAS £58 INCLUDING VAT AND MAKE SURE YOU TAKE ALONG ALL DOCUMENTS TO ORDER TOOK ONE WEEK TO ORDER MINE :D :D HOPE THIS HELPS YOU
Status
www.W140.co.uk&www.r129.co
