Immobiliser probs
Jon72
I have an M Elegance c180 auto...over the two wks ive had probs with it not starting because of the immobiliser, & cutting out during driving!
Has anybody else had this prob? how could i disable the immobiliser?
Hi Jon,,why do you think it is the immobilizer
Jon72
The green and red lights flash on the door panal.....and the sensors are flashing when i get into the car! tried disconnecting the battery and sometimes it starts sometimes doesn't!
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Have you got red & green L.E.D.'s in the rear view mirror?
Are these both working?
As one of these being blown can cause the symptons you are describing, though i have never heard of the car cutting out once the car has been started.
Have you replaced the fob batteries? even if the fob is still opening the car ok replace them with new.
Have you tried your spare key fob?
Perhaps Andy he can use it with this post
http://forums.mercedesclub.org.uk/showthread.php?t=42002
Jon72
hi
i go to open car and green and red lights are flashing on handle as if alarm has been set off.so then i get inside the car the sensors flash as if alarm is still on.disconnected battery and left it for a while then car started.after journey locked car.then later opened it and still wont start!!!with both lights flashing again.can i disable the alarm immoboliser?
thanks if anyone can help
jon
Jon72
Can i disable the immobilizer ?
The immobilizer is a MB dealer fit, and you can remove it, a fiddly job as the wires that were cut to fit the thing have to be joined up again, they are all colour coded and a few have done this
Jon72
is there anyway i could find a step guide on how to do this online?
Sorry there is not, there are also many different versions.
There are the CD's on Ebay but few can get them to work and they are not easy to use. these Disc do have the dealer retro fit for the alarms,, perhaps they could be used backwards,, no promises but this is the third time that someone has asked to remove their alarm. I cant look today as these things are time consuming but I will look up this to see if it is possible to give some info out
