Indicator switch
Mlingane
Mercedes w203/2002/270cdi
My W203/270cdi indicator flashes to the left anytime while driving non stop for a long time, when switched to turn left left it flashes to the right, when switched to flash right no problem.
Wearsafoxhat
Sunny Hampshire by the sea
E55k :S211, SL500 :R129 , V220
If you only have this problem, possibly the stalk.
If you have other electrical problems similar to “power cuts”, eg put the wipers on,the radio goes off, along with indicator problems, could be the ignition switch.
M
Mlingane
Thank you for the response, there are no other electrical problems, the radio plays normal and the wipers are fine its only faulty by indicating to the left even if l am not turning at all just out of the blue.
rifiki
Worksop
CLK W209 W121190B
Multi function stalk is a known problem. in my case it was the windscreen not working, new stalk around £90.
Tel: 020 8863 9233
