injector on w209
mercman111
ledbury
2005 clk 350 petrol
what holds no2 injector in 2.7 diesel,i have a puller set with a fork and slide hammer but it will not budge i have also extended the slide bit of the hammer
Mark A
Aberdeen
58 ML-320CDI.
Did you get the engine nice and hot first??
M
mercman111
ledbury
2005 clk 350 petrol
no i got the threads stripped on the injectors
arion
190e
Assuming you have the one torx bolt removed and the holder then it´s usually soot that has seized the injectors.
You will have to keep trying the slide hammer. Spraying WD40 or Carb cleaner around the injector and leaving it for a while can help it loosen up.
M
mercman111
ledbury
2005 clk 350 petrol
i think the injector has been glued in,there no side movement,and no matter how i use the puller it does not budge the injector
