Injectors!!
Dwg_23
Stoke-on-trent
2010 C250 estate
Hello all! I have a 2005 c220cdi
I have a small misfire/splutter at low revs while driving
Plugged into star--no codes
Injector values
Injector 1 -1.47
3 -2.64
4 +2.39
2 +1.71
Garage thinks number 4 can cause the splutter and maybe number 2 is high as its trying to compensate?
Your thoughts please! Thanks guys
mersum1es
Finland
Star also says, value which requires a new injector is more than 5. From reading experiences, around 3 values may cause starting problems etc. so not necessarily caused by those injectors.
D
Dwg_23
Stoke-on-trent
2010 C250 estate
I'm just getting a misfire/ hesitation at very low revs on motorway ect, no codes have come up on 2 plug ins, do you think the injector could cause a misfire at these values?
mersum1es
Finland
complete 'misfire' sounds very odd, some irregular rpm is more like usual. Perform a return leak test to the injectors, correction value does not always correspond with those results.
drdre78
london
mercedes c200 200
last time you change fuel filter?
D
Dwg_23
Stoke-on-trent
2010 C250 estate
Fuel filter was changed recent, garage can't find anything,
mersum1es
Finland
Hi
Please enlighten me. What are these numerical values ?
It's more like balancing the difference between the cylinder, as you see sum of the values is near 0.
D
Dwg_23
Stoke-on-trent
2010 C250 estate
Replaced injector 4 and that has gone back to minus now
But cylinder 2 has gone up a touch to 2.8 so Maybe that one needs doing now
D
Dwg_23
Stoke-on-trent
2010 C250 estate
Replaced injector 4, injector 2 has gone to +3 now, rough running and a knocking since swapping injector 4 for a refurbished unit??
mattkh
England
A160 W168 1999 1.6
Hi
Please put up a picture of an injector that you have removed. Cheers.
D
Dwg_23
Stoke-on-trent
2010 C250 estate
Hi it's been the garage I haven't got them,
