Installation of cruise control - tempomata A klasa w169 a180cdi
zdravko
a klass w169 2007 diesel
trebam jedan savijet da li je itko naknadno ugrađivao tempomat na mercedes a klase w169 2007 god. a180cdi, hvala
I need some advice on whether anyone subsequently installed the cruise control on a 2007 Mercedes A-Class W169. a180cdi, thanks
Hello and welcome,
Please post in English for best response
zdravko
zdravko
Hello and welcome,
I need advice on whether someone subsequently installed cruise control on a 2007 Mercedes A-Class W169.
@GLK is probably best suited as he's done quite a bit to his
A.J.
Norwich. UK
Hi and welcome to the forum :)
zdravko
zdravko
[QUOTE = "John Laidlaw, post: 1829516, član: 68209"] Dobrodošli od mene i mog mađarskog prijatelja < : D[/ QUOTE]
greetings to you too
Mike-Carter
W169
Welcome Zdravko, Christ, tried to pronounce you name and 1st post out loud, all my teeth fell out:D
I'm hoping you get an answer as I'm interested. Companies here in the UK charge a ****** fortune, as all the electrics are in place on a 2010 A-Class we're just being stung.
ZZZZ
Not sure that I am - mine had cruise from factory, as it's an automatic (CVT).
I'm almost certain @Alfie retrofitted tempomat to his son's W169 (manual), and I know @area51 have done the same on his W168.
I did have some impure thoughts of retrofitting a linguatronic stalk, and assigning a completely different function to it, just so all possible levers are present on the steering wheel :rolleyes: Haven't completely abandoned the idea ...
zdravko
zdravko
[QUOTE = "GLK, post: 1829653, član: 72811"] Nisam siguran da jesam - moj je imao krstarenje iz tvornice, jer je to automatski (CVT).
Gotovo sam siguran da je [USER = 8387] @Alfie [/ USER] preuredio tempomat na njegov sin W169 (priručnik), a znam da je [USER = 21722] @ area51 [/ USER] to isto učinio i na njegovom W168.
Imao sam nečiste misli o tome da preuredim jezičanu stabljiku i dodijelim joj potpuno drugačiju funkciju, samo tako da su sve moguće poluge prisutne na upravljaču. : rolleyes:Nisam potpuno napustio ideju ... [/ CITANJE]
Thanks for the effort I think the w169 has factory support for cruise control just need to install a lever and encode the ecu, I wanted to contact someone who has already done so, greetings from Croatia
Well I've done it on a Smart and all it needed was a new stalk, some wiring and recoding the ECU. On the Smart it required a TAN code to activate it.
Not sure if the 169 needs a TAN code or not.
The best man to answer this is @forrera on here.
