Can anyone please point me towards the fuse for the Instrument Cluster?
I have a 2001 W203 C200. I want to see if the fuse for the instrument cluster has not blown.
There won,t be one dedicated fuse for the Instruments as the inputs for the gauges and the lights are sourced from different systems.
What is the problem you have with the cluster?
Basically, the problem is all the gauges and elctronic display as well as the light in the cluster are all 'dead'. however, the car starts up fine and drives fine, but bo speedometer, rev. counter or anything.
I found a fuse map [A 203 545 08 00] and there is a fuse labelled No.42 which refers to the Instrument Cluster. The fuse is located in the cockpit on the drivers side.
I have not yet checked the fuse in my car yet, but I do hope that this is the problem.
