Intake Air temperature sensor 2 - OM651
Duffie
W212 220CDI - 2009
Hello All!
First post, long time lurker. Great, and very helpful forum.
Anyways..to the case..
I have a 2009 W212 220 CDI with the OM651 engine.
I have an error code that wont go away, and am researching the cause of this.
My question really is this:
Does my engine have more than one intake air temp sensor? I take it sensor 1 is located around the air intake. Can anyone give me the location of sensor 2?
Thanks alot!
D
mattkh
England
A160 W168 1999 1.6
Soooo......... you clear the code using your code reader and then when you use the car, the code comes back.
Have you changed anything..?
D
Duffie
W212 220CDI - 2009
Thanks for your reply.
I clear the code, and it comes back once i cycle the ignition.
I just need to find out where this sensor is, so i can start troubleshooting it :)
mattkh
England
A160 W168 1999 1.6
Found it.
In the big inlet pipe leading to the air filter.
D
Duffie
W212 220CDI - 2009
Found it.
Awesome! And this is sensor 2?
Thanks alot for the help!
mattkh
England
A160 W168 1999 1.6
This is the only intake air temp sensor.
Clean and check the wires and pins on the connector.
Please take a few piccies if possible.
D
Duffie
W212 220CDI - 2009
I cant seem to find it.
Theres a map sensor on there(removed on pic) and another sensor thats on the breather pipe From valve cover. No IAT sensor in sight.
mattkh
England
A160 W168 1999 1.6
Thanks.
According to my research, this MAF sensor is not a normal MAF . It incorporates a temperature sensor. It sends a temperature signal to the ECU as well.
Give it a clean with an appropriate spray cleaner and see if the code comes back. How oily does it look inside.?
D
Duffie
W212 220CDI - 2009
Pretty good that.. Dont Even think i have to clean it..
mattkh
England
A160 W168 1999 1.6
Thanks.
I dont have a wiring diagram otherwise we could have checked the connectivity of the cables.
By the way, how many wires can you see.?
Give the connecting pins a clean and check the jaws in the plug, while you have it off.
D
Duffie
W212 220CDI - 2009
Yes.. Theyre cleaned and look like theyre brand new.
4 cable on it.
Error still occuring
Thank for you continued help
D
Duffie
W212 220CDI - 2009
Managed to find the short.
There is a wire on the left side of the engine. Orange and grey/Black color that had shorted. This wire runs under the a/c pump and towards the front of the engine. I imagine this wire goes to a iat sensor located after the intercooler, but havet checked.
Anyways, code now cleared.
Thank for all the help troubleshooting this.
