Interior fan motor "humming"
Daeths
North Kent
T212 facelift, 2013. A few toys including pan roof, 19" rims, Harmon Kardon, nappa, privacy glass.
Hi all.
Haven't posted for a while which is a good thing cos the cars been going aok. New niggle...
Car is a 2001 T210 320cdi. Ventilation is the two wheel jobby, i.e. not digital climatic. When the fan is on, after about 1/2 minutes there is a noise which is very faint which sometimes follows engine revs, but often still there on tickover. Fan works perfectly but the humming is annoying !!.
Any ideas what it can be, is the motor on its way out :-(
All and any thouoghts always appreciated
Ellsy Tanners
Mars
Hello,
Does it make a differnce with the a/c on or off. could be the compressor making a noise coming back through the car.
jberks
Be aware that the regulator can make exactly the same noises as the fan. Mine squealed exactly like a dry fan bearing. The indie suggested it would probably be the regulator and eventually (4 months later) it started varying the fan speed erraticaly (switch on 1 - speed up to full and back down again as you drive along) which fortunatley gave the game away. Popped a new one on and it was all quiet again.
Regulators are more common failures than the motors but to be fair it could be either.
D
Daeths
North Kent
Hello,
not tried this will give it a go and report back
Adam
D
Daeths
North Kent
Be aware that the regulator can make exactly the same noises as the fan. ... Regulators are more common failures than the motors but to be fair it could be either.
Hi Jberks, if it is the regulator is this an easy diy and cheap (or chep indy job?)
out of interest what does the regulator go /
Cheers
Adam
Wezzel
My car had what I thought was a noisy compressor. When I turned on the aircon a humming noise could be heard. I was going to get the system investigated but in the meantime had the aircon re-gassed and the noise went away.
It has been fine now for months.
jberks
Cheers
Adam
From memory the part was £125 from MB. Couldn't find it elsewhere. And yes it's easy - it took me 20 mins to swap them over.
The switch puts out a small current of between (roughly) 0 and 7v. The regulator then translates that into enough current to run the fan at the appropriate speed.
D
Daeths
North Kent
Adam
when i push the EC button th enoise goes. waht does this mean, is it related to a new polybelt i had fitted - only noticed since then (but it might be coincidence)
cheers
Adam
