Interior front lights & clock 190e
Status
Not open for further replies.
fletch
Hereford
Recently the clock & internal front lights have stopped working. I think that this occured at the same time but not totally sure. The rear internal light still works when the door is opened & all other electrics including sun roof & windows are working fine at the moment. Any suggestions on likely causes/remedies would be appreciated.
F
fletch
Hereford
Thanks for the reply, any idea where the fuses are ? Are there any fuses in specific for the clock & interior lights or should I just change them all ?
Thanks again
spanners
manchester
Fuses
The fuse box is located in the engine bay on the drivers side just next to the brake master cylinder.
It has a black plastic lid which pops off with the clip at the front. On the underside of the lid, it will tell you which fuse is for what. But looking at the fusses themselves, you should easily be able to see any that have blown as the metal strip across the top will have blown.
I'm not sure if the clock and interior lights are on the same fuse, but they are likely to be as they are both permanently live.
F
fletch
Hereford
Spanners-
Brilliant thanks very much indeed. Will report back when i have checked it out. Once again thanks for your help
Status
