Slartibardfast1
- Mar 2, 2021
- W221 S350L, R231 SL350 & SL400
I've been told that the door panels need to be removed to get the trims off. Dashboard trims are removable with a decent trim removal tool.In my experience very little trim in a mercedes is what I would call easy to remove.
Thanks for your reply, but no need as I've just seen a video showing how to remove the door panel. I've just found out that there are clips at the back of the trim that need to be released. Cheers.Yes I seem to recall the door trims are held on from behind and requires the door card removing (at least on early 230s and my 251).
I have an old 230 door trim somewhere so if I can find it will take a look.
