edward obrien
- Jun 21, 2020
- e350 2010 c207
so first of all hello, and i so hope someone has an answer
So the issue i have is all over google but no real answers , let me explain what the situation is ,
First thing in the morning when i go to start the car , the ESP light comes on along with the runflat inoperative message read owners handbook!! then i turn the key off and on a couple of times and the light disappears and the car will start,
not sure if this is related but the negative battery cable has a module on it its some sort of regulator and that has had some sort of corrosion all over it to the point it dissolved the plug that goers into the module ,
i purchased a launch crp 479 obd tool which has not picked up any faults at all and no engine management lights come on ,
these are the things i have changed or checked so far
eddy
- Brake light switch
- new rear disc and pads,
- new front pads
- negative cable and module that is attached to the cable
- new battery
- Alternator power is between 13-14.65 volts and does not drop with all the power being used in the car.
eddy
