googolplex
- Oct 9, 2002
Wondering if anyone has had similar problems with their W124. My 1989 230E starts fine and idles OK but occasionally (every few weeks or so) it will mis-fire quite severely when accelerating. (cruising at constant speed is usually OK) Other times it runs just fine.
Turning the ignition off and re-starting immediately (two or three times if necessary) occasionally solves the problem. I've replaced the distributor cap, rotor arm and HT leads but the problem still crops up now and then. Any ideas out there before I take it to a dealer? I thought perhaps it might be the fuel pump(s) or a dodgy relay?
Cheers,
Sam
Cheers,
Sam
