P
potion
After an alternator regulator failure, my '95 C280 (W202/M104) sometimes loses power and idles roughly. Sometimes the power suddenly returns. If not, turning the engine off and restarting it restores normality for a while.
Allowing it to idle roughly for a few minutes, and then turning off and removing all the spark plugs reveals that the No 6 plug is wet with unignited fuel. Injector, ignition or control? My local independant M-B agent says "control": he's not sure, but thinks that the ECU is cooked as a result of the over-voltage and needs to be replaced. He cannot verify this because his diagnostic computer has limited functionality.
Q. If I take the car to M-B, will they be able to pinpoint the problem?
Q. If it is the ECU, can I replace it with a good second-hand unit, and if so, must this unit be re-programmed before it will operate properly?
Q. If it's not the ECU, then what else?
Den
Den
