Intermittent Starting Problem - W124 - 320TE
Jixes
Mercedes 320TE - 1993 - 152K (driven daily)
Since November we have been experiencing an intermittent starting problem with our Mercedes W124 Estate. Normally the car starts without fault on the button, but occasionally the starter motor will turn over and over without the car firing into life. Turning the ignition off and and commencing the starting sequence again with the key, the car will start immediately (80%) or it will just turn the starter motor over as it did on the previous attempt (20%). It seems that by restarting the ignition sequence again helps the car to start. When the problem first occurred we use to leave the car for 10/20/30 minutes and then restart the car with success. The problem seems to happen after a short journey when the engine is warn (and on a warm day), not when cold, but that maybe coincidence.
I am inclined to think that the problem is more electronic than to do with fuelling, as I have tried on many occasions to depress the accelerator whilst the starter motor has been turning over.
The problem hasn't happened for the last 3 months, but started again on Monday when my wife pulled into a garage to get fuel and couldn't start the engine again, until I arrived 1 hour later and started the car on the 2nd attempt, after turning the key on/off twice. (she wasn't happy). She then used the car all day on start stop journey's without the problem re-occurring.
On Tuesday evening (after sitting outside my friends house for 3 hours) I was fortunate enough for the problem to occur again, in the presence of my mechanic and we tried different starting sequences so I could show him the problem. He's going to have a detailed look at the car and suggested that we take it to a diagnostic specialist he knows, but as the problem doesn't occur very often it may be difficult to trace and may need the problem to get worse before it can be diagnosed. Since Tuesday the car has started on the button and the problem has disappeared, again.
I was wondering in anybody else has heard of anybody experiencing this kind of problem and knew what may be causing it?
James
PS - Next time it happens I will see if I can video it to capture then problem. I will also post any findings/solutions to the problem as I find them.
The crankshaft sensor can cause this, if it was the other ECU they would not behave that way,at £46 from bosch it must be worth a go
Cosworth
It might be a faulty OVP relay, very common to go.
Same thing happened to my fathers car.
Normally the car will run with the OVP relay faulty, its puts the ABS lights on, there is always the odd men out
Myros
R107, S211, R170, C219
it sounds very like the ovp fault I had
with our 202, which brought me here all those years ago, costs about the same for the part as the crank sensor.
Jixes
Thanks for all your advice. I think that i will start by replacing the crankshaft sensor and see if that solves the problem. I will let you know how i get on after a month or so, if the problem reoccurs.
Wendal
Birmingham
CLC220
I had this problem on a Bmw and it turned out the earth strap was missing from the battery. The car started most of the time but sometimes wouldn't. The garage said the car was earthing with the body on the times it was starting. A missing earth strap is the same as a rusty, damaged one so worth a check
mike7
Hello,
I recently had the fuel pump relay pack in after a few intermittent stops, but all within 2 days.
I would listen for the pump coming on. If no pump, no fuel, no start....
