d215yq
- Mar 28, 2008
- Age
- 40
- Location
- Valencia, Spain
- 1987 W124 300D 280k miles
Today I put the window down fully to wipe clean the mirror and then it wouldn't go up. Swapped the switches at road side and that didn't work and as I couldn't find the fuse diagram I just checked all fuses and found the culprit and replaced and it now works.
Would anyone investigate anything further or is it just the case that fuses blow occasionally. My only thought is the windows in the colder damp climate here don't go up and down as freely as they do in warm sunny weather I'm used to so maybe that's what blew the fuse?
Is there a way to improve lubrication in the widnow mechanism that you can't see without messing around with the door cards? Could I for example liberally pour engine oil (I have some old stuff left over) between window rubbers with window down and hope some of it makes its way to the mechanism. I don't care about spilling it/any mess, I can clean it after and the door cards/paintwork aren't pretty anyway. I just want to ensure the window motors don't burn out/mechanism breaks and don't fancy taking the door cards off (my experience with this when I took them off last time on a Rover was they are impossible to get back in and all the clips break off, etc.
