bwh
- Nov 1, 2006
- 300e turbo diesel 1998
300te diesel
the kick down often does not work, especially if the revs are around 2100-2500, is this just a matter of adjusting the throttle cable?
The kickdown didnt work at all when i first got it, so after a while dropped down using the gear stick this seem to help as kick down would then work sometimes ,gradually improving with time. Then noticed that the plastic adjuster on the cable was brocken, so cobbled together something to bring the tension back to what should be about right, but just cant quite get this last bit right, or do these just not go down on those revs?
Any ideas would be great!
