Is ATF fluid into fuel and added to engine oil for VITO 111L diesel van good ?
ednabilin
indonesia
van
hiiii...
can anyone advise me if adding ATF fluid to the engine oil and fuel good as a detergent for my VITO 111L 2149 diesel turbo engine (2005 model) ?
thxx
lin lin
MechPhil
Brandfort, South Africa
'87 260E
NO! Atf is not a good detergent at all and should not be added to engine oil! Adding a small amount (250ml to 50 litres of fuel) to diesel fuel should nor cause any damage, but in my opinion also will not do any good.
Phil
47p2
Scotland
If you are buying your diesel from the forecourt there is more than enough detergent in it and you should not be adding more
Frontstep
T210 320cdi
Does Singapore have a difference in Diesel standards ?
wireman
lancashire
NO & NO, don't risk it.
E
ednabilin
indonesia
van
Phil
ohh ok....
i saw a posting by someone (from MB Club UK forum) that he had used ATF to add to his diesel van in the fuel and engine sump and it gave him good results...that was why i was curious if it really was that good...
thxx PHIL
E
ednabilin
indonesia
van
...ohh..here in singapore...we buy diesel from like SHELL or MOBIL or CALTEX etc...i a not sure of the grade though...
thxx for the advise JOHN
E
ednabilin
indonesia
van
hmmmm....good question...i am not sure how the standard of diesel here compares to other parts of the world but i guess Singapore being a very transparent and good governed country,,,,it should be good quality....
S.Speed
Lancashire
Older Citroen Now :-(
Never heard of ATF being added to Diesel fuel...
BUT
I have certainly heard of standard Two Stroke oil being added in small quantities (200ml to a Tankful of Diesel)..
Some swear by it for adding lubricity (slipperyness to low sulphur Diesel fuel)..
E
ednabilin
indonesia
van
BUT
ok..thxx SIMON...
i think i will try it out....any kind of 2 stroke oil or is it a specific brand or type (synthetic etc).... ???
lin lin
E
ednabilin
indonesia
van
BUT
oohh ok...
thxx S SPEED....i will try it out..
is it normal 2 stroke oil or is it a special grade (synthetic etc) or brand (SHELL etc) ???
lin lin
Dosco
W211
If you are using well known fuels then you should not need anything adding.
drdel
Beds
2011 e class 350 cdi est
Do not do it.
Several diesel drivers advocate a small amount of 2stroke oil can help; but only really in older non-common rail engines.
E
ednabilin
indonesia
van
Do not do it.
..ohh ok....
谢谢 Dr DELL....
jefrs
Berkshire
S210 98 E320 Estate Av petrol full load
Diesel fuel /is/ oil so no point adding 2-stroke, it is not a BSA Bantam or an old lawn mower. That stuff is an upper cylinder lubricant to be added to petrol which has no lubrication properties, which a 2-stoke engine needs.
If you must, then add Redex Diesel to clean jets about twice a year if using dodgy diesel fuel.
