Is fitting a Steering Rack Gaiter this way Feasable?
Brian23
EClass
Is fitting a Steering Rack Gaiter. Is this way Feasable? I know that you can fit a CV joint gaiter with a cone.
A lot of the gaiters (MB oem) are hard ish plastic and not rubbery like cv gaiters, so cannot be fitted like that
B
Brian23
EClass
Thank you. The replacement boot that I have is a rubber one.
Then, yes
EmilysDad
Bury Lancs
ML350
That track rod end looked past its best .... and no axle stand :oops:
mioba
Nottingham and Köln
If it works and that os the only damaged part needing replacement then why not. The method seems feasible, the safety is questionable to say the least, so work safely.
noonboots
R230 SL 500 2003 M113 5.0l
For the sake of undoing the lock nut unscrewing the track rod end why you you bother forcing the gaiter over it.
As often as not if I were reusing the track rod end I would unscrew the track rod from the track end without splitting its joint. It avoids damaging the rubber gaiter.
To avoid re-aligning the steering afterwards. Even counting turns etc, its never that accurate.
noonboots
I never let a car leave my workshop after steering work without checking the tracking. Doing so would rely on it being right when it came in. If it wasn't and the car scrubbed it's tyres quickly guess who would be getting the comeback.
B
Brian23
EClass
Yes I agree and yet I took a car into a garage in Aylesbury for a new track rod end and had to take it back 3 times for them to get the tracking right. That what happens when you listen to recommendations from friends and use a different place.
DREAMER NO2
W124 2.6E M103 1989
Nice job there i would go the long way,, not knowing about this little trick ,.and take off the ball joint ,,,not any more i wont,,that is a very good idea .Abd you could help the new gaiter along with some silicone grease
B
Brian23
EClass
When the weather gets better and I finally get to it. I will also warm the rubber, maybe in hot water to make it more pliable
