is it broken ??
Daeths
North Kent
T212 facelift, 2013. A few toys including pan roof, 19" rims, Harmon Kardon, nappa, privacy glass.
Have a 2001 E320cdi T210.
Having general check for leaks an stuff (aok) over the weekend as part of the preventative maintenance and thought I'd twist the 'dial' on the airfilter to see it was working properly. - this is the one that twists round and increases a white to red when the filter is blocked (hopefully I've crudely explained the piece in question).
My query is that I cannot twist the dial by hand, it moves a fraction and then just locks solid. Clearly this means a reduction in the performance of the air filter will not be visible from this dial.
Does this mean the filter is blocked (if so would expect it to be jammed on red, not white) or is it something else ??
Or should I not be able to twist by hand and I am worrying about something that is not an issue - it's been known :-(
Thx in advance.
Jacko918
Not sure about yours, but the ones on the sprinter go red when there blocked. The knob is there to reset it to white. Once reset to white, the knob won't move. So I would guess this is normal and there's nothing to worry about.
When white it is OK so have a good new year :D:D
D
Daeths
North Kent
Cheers gents, a classic case of my little/wrong knowledge getting me nervous.
HNY 2 u 2 :D
