Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
I was surprised when I picked up my donor wheels and the fitter tightened them in a circular pattern.
I was pretty sure, it even stated in the manual to do each nut in a diagonal pattern ( like you tighten a cylinder head to avoid warping).
Any way when I got home (30 miles) I read the manual, and yep it said tighten in a criss cross fashion.
So as the donors will be on the car for 6 days, I jacked them up and loosened them off and then retightened, in a criss cross pattern, and did them to the 150 Nm.
They were tightened to 120 NM.
If, and I say if, tightening them in a circular pattern (one after the other ) distorts anything, what gets distorted the wheel, or the hub and or the disk?
If it distorts either the hub and or the disc, is the damage done when its tightened up, or over time? i.e. Was it worth me undoing them jacked up and then retightening them in a criss cross pattern.
Also if they didnt do them up to 150NM but only 120 NM would that have helped prevent distortion of the disc and or hub?
I ask as although the wheels were firmly on when I got home, lets say I missed my stable non-vibrating, go where you point them, wheels on the way home.
I assumed the donor wheels were buckled and a tad out of balance. And or possibly somewhat incompatible tyres, weird make "Lands xxxx" something or other.
