nj80
- Nov 13, 2023
- C class coupe 2017 250D 4matic
Hi all, new to this! I just purchased my second w205 250d coupe (2017) and the drive is a little off and millage is poor... is it possible to have No engine warning light, but multiple error codes? is there a known reason that could happen as ive seen someone else ask, but hasn't gotten a response yet
I used Carly scanner which showed the following
P229F85 The NOx sensor 2 (cylinder bank 1) has a malfunction.
U010000 Communication with the control unit 'combustion engine' has a malfunction.
U11A300 Communication with control unit 'Multifunction camera' has a malfunction.
U016887 Communication with the electronic ignition lock has a malfunction.
B1F4500 The starter battery has excessive resistance.
B21059A The capacity of the starter battery is too low. The operating conditions for the component or the system are not satisfied.
U010000-Communication with the control unit 'combustion engine' has a malfunction.
U041600-Implausible data were received from control unit 'Traction system'.
U010000 : Communication with the control unit 'combustion engine' has a malfunction. / -Communication with the control unit 'combustion engine' has a malfunction. / C10000 Communication with the control unit 'combustion engine' has a malfunction.
If anyone can advise I just would like to get a better understanding when I deal with the company and warranty or I may just give the car back... thanks
