Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
In the charge mode its getting to 14.7V ; whereas it used to stop at 14.5V!
Once it reaches the care mode it does drop Back to a "normal" 13.8V.. the Ampere output is correct.
Is 14.7V too much ... could it damage the car.?
I ask as "off charge" the current drain is 0.040 to 0.01A
On Charge at 14.7V and one sees the drain is 0.150A. So it looks like its waking up something???
Background:-
It got very hot once, last month, and I rang CTEK in Sweden (there is no support in the UK). They explained it can do that. And as the amps and volts were right I dismissed this little glitch.
This week having not used the car much, I gave it a "top up" charge. I thought It seemed to get to the end of the cycle much faster.
After the charge, I was fiddling for a few mins before starting the engine, and got the "Start engine in 3 mins or Command with switch off.
Not seen that since the defective battery issue, now replaced and both car and new battery tested and passed with flying colours. So wondered did it not charge it properly?
My concern is when it got hot, and boy was it hot. Did it damage something that regulates the voltage.
My old accumate said it was 14.4V max. And thats what you got!
I know some chargers have an initial high 15.3v charge as part of the desulphation cycle ( btw definitely not recommended for AGM batteries) . Mine was deliberately chosen, as it does not do this .
But does a sustained charge of 14.7V harm a battery ?
Info
At the end of the charge its registering 13.0V and this initial Charge drops off over an hour to say 12.9V, and next day 12.8V.
Background:-
Info
