Isopropyl alcohol prep
John Laidlaw
Wirral
Land Rover Discovery 4
I get you now Andy. Yes mine is a slight L shape and as you say hangs over onto the boot face. There is a little half moon shape also to accommodate the star badge, whereas looking at yours it’s just flat. Wonder if the W204 OEM one looks like that or like mine?
Capra
Capra
Gloucestershire
W204 2013 C350 CDI Pan roof
  • #22
I've seen some more expensive ones with more of an L shape, mine seems to be more generic. I don't mind just as long as my car doesn't look like it's been owned by a 19 year old that reads Max Power!!
John Laidlaw
Wirral
Stick it on with some Blutak Andy before attaching it properly and leave it on for an hour or two, take a few photos in different lights (not drive it of course!). That way you can sensibly decide. Nothing worse than doing it then think it’s naff.
I did that with mine on a Saturday morning (I was lucky, being in the L it just sat on), before deciding it looked right and did it permanently.
Capra
Capra
Gloucestershire
  • #24
Good advice John, I've seen them online and they look ok, but this is me fitting it! You also have to create the curve yourself and this is not pre-curved to the shame of the boot.
I will do this Saturday morning while I am applying the CHIPEX, which I have to say the kit contains everything, not sure I will require the added polish, but maybe that is designed for this type of touch-up.
Capra
Capra
Gloucestershire
  • #25
Ok, some blue tacked in pics. Getting the start correct will be a challenge as there is no obvious edge.
V6Matty
Newark, Nottinghamshire
Looks a little to far away from the rear edge to me, not bad but I think 5-8mm closer and you'd be right
Capra
Capra
Gloucestershire
  • #27
Thanks Matty, the bit on the left side does look further away but it's a little raised because of the blue tack. Or was it the whole things in general? I was using my thumb to try and get it as flush as possible, very tricky. It also moved a fraction when some of the blue tack came loose.
V6Matty
Yeah might just be because of the blue tack, but I'd be tempted to get some masking tape around the edge of where you want it to finish will be easier when you try to fit it too
Capra
Capra
Gloucestershire
  • #29
Just on each edge?
V6Matty
That would work, personally I'd run it across the entire rear then you know your getting a perfect finish to the edge if the boot
Capra
Capra
Gloucestershire
  • #31
I ran some masking tape, but was still a job getting it right. Looks ok, the edges could have been a bit better.
V6Matty
That looks cleaner than before, the edges don't look bad either I think it's the light now
Capra
Capra
Gloucestershire
  • #33
Cheers, it's not 100%, but I think I would struggle again if I was to remove a start over, plus the wife came out mid way and said "what you doing", before rolling her eyes and going back in the house. this was then followed by "how much did that cost?"
BTW both edges are a few MM from the edge of the lid.
John Laidlaw
Wirral
Sorry Andy I was forced to be forum free for a while since the wife’s off early morning on a girls weekend...
I clean forgot to mention the placeholding with masking tape bit - doh! That’s the way...anyway your last one looks fairly spot on so you got there with Matts guidance !
Capra
Capra
Gloucestershire
  • #37
Cheers John, yeah Matt was spot on. The hardest part was how to start, but looks ok, I'm happy with it.
Glynn350
e350 cdi cabriolet 2012
Can you post a link to the spoiler you bought? Looks like a good product
