It wont start up?
miliTanT__ALi
i have merc e240 w reg and the problem is that when i try an turn ythe engine on it just doesn't start up. the remote opens the doors fine all the lights up turn on put the key in the steering lock up comes off lights turn on but just doesn't turn the engine on anyone know whats wrong?
thank you
ali
brandwooddixon
Wolverhampton
S63 Coupe 2014
Have you tried a spare key?
It is quite common if the key fob batteries are low for the doors to unlock, but the car not start.
You may have a K38 starter motor isolator that is playing up. You really need to get a meter onto the end of the starter motor to see if 12v is there with the key turned to start
M
miliTanT__ALi
yeah i tried the spare key didn't work either
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
do your electrics flicker when turning the key, could be a duff battery if so, have you tried a known good battery ?
jberks
If the car detects too low a voltage it will just refuse to turn over. (Its a merc thing). All lights will work, it will unlock fine, but no cranking, let alone a startup - sound familiar?
Check the battery.
