Jacking Pads Heads Up, Fitted to 639 but Likely Most Others
M80
Derbyshire
I jack up on an inclined driveway, and chock the other wheels.
Likely that has bearing but the jacking pads on this and previous 639's didn't last long, the flared retainers would snap and the pads would then hang loose and fall out.
So yesterday I removed the bungs I'd fitted, and pre treated with Dinitrol RC800, sprayed with caliper paint, and fitted these -
www.ebay.co.uk
4X Rubber Jacking Jack Pad Point Lift Adaptor Fits Mercedes Saloon W124 SL R129 | eBay
A124 S202 S124 C208 C124 C215 W124 W202 W208 W210 W220 R129. 4X Jack Pad Support Lift Rubber Jacking Point Pads. Ending Soon. COLOUR IS BLACK. Our Part Number : C406x4. Original Part Ref. Number : 0019979586.
www.ebay.co.uk
They are remarkably cheap, feel much more robust than the original, and have a rubber flared base that offers better hold.
I've jacked up all four this morning and, so far, impressed with the results.
I'm intending to check the 211 and if they use the same type as expected that'll get 'em as well.
Tip, if you go for these.
Remove the flaring centre pin,
drive the pad into the hole with a mallet. Then fit the pin and drive that home.
