Jacking Point Rubber Gromet
SQ_W211
W219 CLS55 AMG
Hello All,
2 days ago I was at our local sport center, when i tried to reverse park in to this tight space, i accidently went over a raised kerb which rubbed under the body below the side skirts. I then saw some black mark on the kerb which was from this rubber groumet which is used as jacking point (Rubber had also come out of the housing). I think its a straight forward push on job but just wanted to double check if that is the case and how easy it is push it back in. I do not want to damage anything while doing it.
Should i use the original part of buy a replacement one from merc?
Many thanks
Cole@MBS
www.mbssouthampton.co.uk
You push the outer cover in first Amo, then the center peg spreads the insert keeping it a tight fit!
brandwooddixon
Wolverhampton
S63 Coupe 2014
I believe that they are just a push fit.
I had one replaced once on mine during a service - I hadn't even noted that it had gone!
I don't recall it being expensive so I'd approach MB first.
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
If it is the same as a C class (which it should as a 208 is built on a 202 floorpan) it is item 68 in the link below,
http://www.detali.ru/cat/oem_mb2.as...332F794887&CT=F&cat=44V&SID=60&SGR=030&SGN=03
Yes you should refit it as this is what the workshop ramp sits on when the car goes into the garage also can be used for a trolley jack support (if you use one).
The centre should push out so far, push the main body of the pad into the hole it came from, once located either push, tap home the centre with a hammer.
Just make sure there are no locating lugs damaged when it got dragged off.
I bought one new for mine it was approx. £10 from the stealers.
Cole@MBS
Yes Andy, Amo,s car will be on the ramp saturday, so it would be handy if all four are there!
Hint hint Amo!!
SQ_W211
SQ_W211
W219 CLS55 AMG
:eek: I will have a look but from what i looked at, i couldnt see anything like outer cover.
By the way what time shall i get to you on Saturday? I have the whole day now as i am not going Scotland so we dnt need to do this early morning.
Cole@MBS
If we can keep to the morning as planned Amo, booked other work in after your good self Sir!
Do you want me to order you a new jacking bung for sat, or have you got it covered???
SQ_W211
SQ_W211
W219 CLS55 AMG
Yes please, it would be better if you order one Even though i think the older one isnt damaged as it has just come out but rubbing on the pavement.
I have just sent you a message, can you please check for me?
Cole@MBS
Got it Amo, No problem at all, see you sat morning!!!!!
