when useing the normal jack at the rear ofside point i noticed that the point was not as strong as the rest of the car i/e it started to make that noise can any one tell me what it is going to cost to have the area replaced/repaired.
Its doubtfull that any body will quote with out inspecting the vehicle. It is my experience that if the jacking point is rotten. Then the job is usually bigger than it looks. IE, you can only see part of it. When you start digging. Usually you wish you hadn't started.
Visit a good body shop. Or one of this sites specialists in restoration work. That way you will know that a good job has been carried out & not a bodge job.
thanks for the info but after thinking about it part of the fault i/e noise may have been caused by useing the jack when the car was at an angle (two wheels on the path) but i will still have it looked at. But it does seem a little odd to me that it is the offside of the car that is suffering from metal worm and not the near side.
Andyk
Peter Best Insurance is a leading specialist in Mercedes-Benz insurance. All MBO members are eligible for exclusive rates on all our classic car policies. Call now for our 'BEST' quote. Tel: 01376 573033
