juddering 211 , defo gearbox related
bembo449
gainsborough , lincolnshire
whats the likely culprit , im thinking TC is going south as the car is over 195k now , any thoughts ? its a 320cdi saloon
ajlsl600
france
primary culprit. when was oil/filter last changed on tranny ? as might be tc lock up solenoid/valve where/if fitted . prob worth getting codes read as a starting point with a reader/star that can interpret them.
bembo449
bembo449
well ive lost count of the times ive saved this car from the scrap yard so I reckon the customer will roll the dice on a box flush but after that , I don't think he will see the worth in repairing it , thanks for your input ;)
star
Reading
Smart + others :)
If he cars on its last legs, just block the tc solenoid valve. It only increases the revs by a few rpm when in top and will eliminate the judder.
bembo449
bembo449
its had a good innings pal , should I try this first ? I may need a bit of guidance as ive never had to touch a box bar servicing them
NJP
Ireland
E320 CDI/04/Diesel
I had a very high mileage w211 e320cdi with a torque converter shudder that I didn't want to spend money on so I bought this
https://www.ebay.co.uk/itm/2-Tubes-...642259&hash=item1c92f6d952:g:OBwAAOSwjLVa4j-s
Within a couple of miles the shudder was gone. I'd say it lasted me about six months when the shudder started to creep back in. So I bought another two tubes! I probably went on for about 18 months like this till I ended up changing the TC. The car had about 450k miles on it when I scrapped it. I was doing about 1000 miles a week.
I'm not saying it will work and I've no connection with the company (not even sure if that was the company I bought it from, first result I found on ebay today). However, if it doesn't work, how much have you lost!
We all know this is not the correct way to fix it before anyone has a go at me:)
Cole@MBS
www.mbssouthampton.co.uk
Probably got glycol in the box, used to be very common,
NJP
Ireland
E320 CDI/04/Diesel
If its a 211 I'd assume it's a 722.6 box. You're options are limited. Spend £15 on the snake oil I suggested or spend 2k on fixing the car. I'd spend the £15 I suggested and hope for the best. Otherwise, the car is an economic write off. I think if it was a glycol problem you would have experienced it long before now.
Anyway the reason for the problem doesn't help the op. I do serious mileage and I'd suggest trying my fix first. Anyway, best of luck fixing it
pgh13
Nr Leamington Spa
E320CDI 2004 - straight 6 diesel
At 160k I drained transmission and replaced filter, then flushed a further 6l through the cooler return, which made an instant improvement, and is still (touch wood) ok after a further 6k. Added bonus, the computer shows fuel consumption improved by about 3 mpg, which presumably is because the TC is now locking as it should
Any update Pal ?
