Hi, I have a 2013 w212 with a rather frustrating problem. The car occasionally jumps into park when the speed drops below 10mph, i.e. when coming to a halt at junctions and in stop/start traffic.
Drive can always be immediately selected without turning off the ignition and in all other respects the car is operating correctly. No problems locking/unlocking or starting.
I believe that forcing the car into park at low speed is an anti theft measure if an invalid key is detected? It happens with both the keys I have and no faults are stored. When testing the Drive Authorisation using my scanner all seems as normal.
Any ideas what is causing this issue? I don't think it is a bad key as it happens when using either one. Is it likely an EZS electronic ignition problem and does anyone know if this can be tested/repaired? Alternatively can the "anti theft" forcing park be disabled?
Ben.
Ben.
