Jumping speedo
davebox
south wales
www.herbaldavesplace.co.uk
Oops! Just when I was filling your minds with praise for the Father in law's C200, the Speedo has decided to start dancing around and sometimes will not bother to give any indication of speed. My mind (what's left of it :shock: ) points toward a cable. Any one know any reason to think otherwise please?
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
Only that it is an electronic speedo and is operated by the pulse signal from the abs sensors.
If the speedo does not work at times then the needle flicks up to the correct speed it is because the needle is sticking to the stop pin, a common problem with the c- class.
See here ;http://64.233.179.104/translate_c?h...tp://www.motor-talk.de/f73/s/&hl=en&lr=&sa=G; The translation's a bit difficult but covers the procedure , in most cases cleaning the stop pins with a solvent is all that is needed.
Cheers, Geo.
C220GJS
Shotts, Scotland.
Grovelling not required on this forum, we're all equals here ,just let us know if it works.
Cheers, geo.
The only thing that I have is, speedometer erroneous =speed signal in the cluster. Hope it make more sense to you than me.
Malcolm
davebox
davebox
south wales
Thanks Malcolm! reading it sounds like conformation of what C220GJS (geo?) said. If I get chance next week to strip it, I'll give it a go.
DB
