Hi folks,
Having just acquired a 2002 A190 semi-auto last week, this is my first post on the site. Generally pleased with the car but I have picked up a few potential problems on the car. I would be grateful if anybody could chip in to back up or dispute my thoughts.
With the car stopped there is a slight knock and a bit of looseness when moving the steering wheel from side to side by a few inches. Also, when moving at low speeds, when I go over a ridge in the road there is a knock. Me thinks it may be the steering column worn? I can see from receipts (and under the wheel arch) that the front drop links were replaced just a few months so I don't think that's the problems.
When pulling away, as the clutch engages there are some strange noises emenating from under the bonnet. If it was a conventional clutch I would probably guess at the clutch release bearing. It's kind of a tinkling sound. (No, it's not me wetting myself on the half-leather seats)!
When putting the foot down in 2nd or 3rd, as you would to accelate during overtaking, the car has horrendous torque steer. Also, I went through some relatively shallow standing water/puddles the other day while driving along some C-roads and the car pulled terribly to the side. Do you guys think these points could also be tied up with a worn steering column (which I understand is a common fault)?
I have booked the car in for the supplying dealer to check the points above, but would be grateful for any additional pointers/info.
Cheers
Cheers
