just how bad can it get
Status
Not open for further replies.
LAMBERT
Ok, now I'm really on a major downer. Can anyone estimate the time required to change the head gasket on my 320sl :(
Spike
London
1999 SL500
I'd estimate about 5 hours work.
If you get it done at an independent specialist, prices vary between £700 -£1000 depending on location.
Depending on mileage, whilst you have the head off, you may as well put in new guides and seals and re-lap the valves etc.
Don't get discouraged, its a pain when they go but not uncommon around the 100k mark.
L
LAMBERT
cheers
Thanks for the info, it's good to know I'm not the only one to suffer.
Andy
West Midlands
www.mercedesservicing.com
The approx time for removing & refiting a cylinder head on a 320 will be 9.5hrs.
Yes it common. Unless its done mega miles I an not so sure I would have the valve out.
If the head gasket is leaking water in a big way & coming out the exhaust. I would have the valves reseated.
Hopes this helps
Regards
Andy @ www.mercedesservicing.com
Status
