The other day my battery went flat as I don’t drive it that often, the key fob unlocked the doors from a distance before I tried the engine and realised it was flat.
I got a jump start to the car and drove to my destination to realise it only works now if they key fob is touching the sensor on the driver side door handle .
I have also lost the radio stations as it cannot find any and will just continue to search .
Not sure what the solution is, I have tried checking the fuses and non are blown , they say if you place the key fob sensor under your mobile camera you can or should see the light transmitting . However both fobs only show the red dot light at the front of the key fob and the batteries are new, taking into consideration the fob was fine up until the battery went flat.
I have had the battery checked too and is certified in working order therefore can put the battery being flat to minimal use but did not think it would have a knock on effect to the key fob signal and radio stations.
I would appreciate any assistance .
