Key fob
jjazzza
scotland
2013 cls 250 amg
I have got 68 plate e class saloon, iv misplaced one of my fobs, but when my other fob is in my house, I can start the car when over 100 mtrs away???
jjazzza
scotland
2013 cls 250 amg
  • #2
Hi guys I have a 68 plate e class salon, I have misplaced one of my key fobs, but then my car is over 100 meters away from my home we're the other fob is located, the engine will start when I push the start button, do you think the misplaced fob is in my car
EmilysDad
Bury Lancs
ML350
Only guessing as I've never had a key less car ... what about removing the battery of the fob you have to rule it out or stick it in the biscuit tin?
If your still starts, then I'd guess the missing fob is indeed inside your car. :)
Altamar
South Wales
2015 SL400
I suspect that is a clue as to where the missing fob might be! As Emilys dad says, make sure the remaining fob is taken out of range/inside a cake tin and then check the lining of your coat for the missing fob...
They don't have a range of 100 metres.
But it's unlikely to actually be in the car as mine won't lock if I accidentally leave the fob in the car.
jjazzza
scotland
2013 cls 250 amg
Hi guys thanks for your replys, looked everywhere in my car. It's over £400 for a replacement, will try to remove the battery from the fob to see if it still starts when I press button
jjazzza
scotland
2013 cls 250 amg
Silly question, how do I remove the battery
Please put up a picture of your key as there's quite a few variants...
Most have a removable metal emergency key, once that is out there is a small spring loaded catch to move then the keyfob opens up
joderest
ML270 2003
If the 2nd key is over 100 meters away, it would be astounding its speaking to the car.
I would search below and along the sides of the seats, or in the grass or shrubs near the car (if there is any) My wifes Mini has keyless go, and unless the key is in the car it will not start.
You need to search, what about in the boot ?, glove box ?
Wearsafoxhat
Sunny Hampshire by the sea
E63 :S213, SL500 :R129 , V220
Why not drive the car away from home, give the key you used to get it to someone ( obviously a trusted friend, passenger) and get them to walk away.
Then when they are away, see if the car starts....
Yes, well it’s in the car and no, it’s at home
richlumb
GLC 350d
You can’t lock a car with keyless entry with the keys inside so unless the car is permanently unlocked they not in the car
Agreed, I couldn't lock the boot on my W213 when my spare key was in my jacket in the boot - took me awhile to work that out...:oops:
jjazzza
scotland
2013 cls 250 amg
There you go
jjazzza
scotland
2013 cls 250 amg
Just started Carr at house left the fob with my wife, drove down road 300 meters, pressed stop button, the pressed again to start, and it started, the car also locks when I press the fob
jjazzza
scotland
2013 cls 250 amg
Also removed the battery from the fob, and it still started?????
TheBlimp75
Milton Keynes
2005 CLS 350 107k
As far as I’m aware the car won’t lock if the key is in the boot not the actual car. So my guess is it’s in the car somewhere ....
Good luck finding it though ....
jjazzza
scotland
2013 cls 250 amg
  • #18
Thanks bl
jjazzza
scotland
2013 cls 250 amg
  • #19
Thanks blimp, still can't find the ****** thing, as people say if it's in the car it won't lock, but it does lock. And if I leave the fob at home and drive 300 metres away the start button flashes and starts
richlumb
GLC 350d
It’s still under factory warranty so get it booked in for a check ?
