- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
- Thread Starter
- Thread starter
- #101
thanks again
coil measures about 3-4 ohms so looks ok
my problem is starting the car
lock unlock is fine
is there anything else i can check?
That reading is very high but this could be your set up, you need to check how well the coil is soldered on the PCB, they can look OK but be dry jointed. You measure on the PCB and not the coil, if too much solder is used then the key will not slide back into the case
