Hi can some one help. E200 yr 98 key fob giving problems it will open and lock doors but will not work the ignition. I am sure there is a simple solution to it. Merc dealers want to charge £170+vat which is daylight muggingempirerighton@hotmail.com
Thank you television for your reply. I tried with the spare key and it works fine but now I have no spare key as the first will not start the car but open doors only I am sure there is a way around it. IF ANY BODY KNOWS I DONT WANT TO PAY £200 TO MERC DEALEARS empirerighton@hotmail.com
If the locking works, but the car does not start then the chances are that the little coil has fallen off the PCB,, they can sometimes be soldered back on
