hi,guys as it was not wet i took my baby out 420sl on aquiet bit of motor way ihit 80mph when i noticed the kick down come on :?: is this normal rgards damien :!:
Hi Damien, when you say 'come on', did it drop a gear? If so you probably pressed the accelerator down too far which pressed the kickdown switch which is underneath the pedal.
Regards
Mike
